video of car bouncing for the first 100 ft
Old 06-22-2010, 06:34 AM
etchison
CRAFTSMAN
Default video of car bouncing for the first 100 ft
http://www.youtube.com/watch?v=IyLRzEutk6g what causes this are my shocks set to loose? its a tube chassis ladder bar car with double adjustables afco in rear. the front end has single adjustables with frontend limiters set with about 1/2" of travel. any input guys? thanks mike
etchison is offline
Old 06-22-2010, 10:09 AM
hammertime
Looks like its set to soft, it spins at the hit, unloads the chassis and spins again 10 ft out.
hammertime is offline
Old 06-22-2010, 10:22 AM
etchison
CRAFTSMAN
too loose? kind of what was thinking. do you recomend tighting the rebound or the compression? what about the frontend? thanks mike
etchison is offline
Old 06-22-2010, 10:32 AM
itsabird
could be both, where is the compression set now? however stiffer rebound would help, what setting on front shocks.
itsabird is offline
Old 06-22-2010, 10:46 AM
etchison
CRAFTSMAN
compresion= #3 on the knob
rebound= 4 spins on the shaft
front coil overs???? the limiters have 1/2'' of travel
car weighs 2580 with driver. car is a small block car with a glide. 4.86 gear. leaving @ 4400 and shifting at 7000
etchison is offline
Old 06-22-2010, 11:55 AM
itsabird
don,t know how many clicks your shock have, but i would go half on compression, and two over half on rebound, and watch the 60, either taking more hit out, or put more in. maybe me but i like a little more frontend travel than that, i am better able to control for the lack of a better word, snap rotation, in other words the frontend comes up too fast, and the tires brake traction. i would try the shock adjustments first, then look at the frontend thing. good luck been there
itsabird is offline
Old 06-22-2010, 12:10 PM
  #7
etchison
CRAFTSMAN
thanks bird!! i will try it this weekend and keep you posted. mike
etchison is offline
