10 Bolt Rear
Old 09-12-2010, 06:43 PM
sfranks56
Default 10 Bolt Rear
I have a 1968 Le Mans with a ten bolt rear with 2.93 gears. Can a posi unit with higher numerical gears, say 3.42 or 3.55 be installed in this housing?
sfranks56 is offline
Old 09-12-2010, 07:04 PM
Housing yes, but not sure you may have to use a spacer plate for the taller gear with your present posi unit. Some people make thicker gears for the low ratio posi units. Do a google search for the gears with your present posi unit.
Old 09-12-2010, 07:36 PM
signsbyesa
if the 10bolt has ears on the bottom, its rebuildable, if not, its not
recommended for strength or abuse, good luck bud :wink:
signsbyesa is offline
Old 09-12-2010, 07:50 PM
fla1976
fla1976's Avatar
Here are a few.
http://www.markwilliams.com/gm10bolt...CategoryID=183
http://www.chevyhiperformance.com/te...all/index.html
http://roadtrip.yearone.com/2010/04/...nd-how-to.html
http://www.drivetrain.com/parts_cata...d_pinions.html
fla1976 is offline
Old 09-23-2010, 03:32 AM
chevyfireball
I'd be shoving a 12 bolt or 9" under there.
chevyfireball is offline
Old 09-23-2010, 04:07 AM
traysvega
JUNIOR BUILDER
I had an 8.2 in my 68 lemans and installed a 4.56 with a spacer,but it didnt last long.Eventually found a 12 bolt out of a chevelle that fit the bill.
traysvega is offline
Old 09-23-2010, 09:18 AM
  #7
JEFF69Z28
I have a 8.5 10 bolt in my monte carlo with moser internals so far so good and the car runs 10.20's.Some one said they were good up to about 650 hp.
JEFF69Z28 is offline
Old 09-24-2010, 11:38 PM
  #8
jonusb
Considering the toronto asian escort above mentioned, we can come to the conclusion that to give up wisely is a kind of more toronto escort mature life attitude. Though giving up toronto asian escorts sometimes is painful and costly,in the long run toronto escorts what we gain will definitely far out weight what we lose.
jonusb is offline
Old 09-27-2010, 12:25 PM
  #9
oldandtired
oldandtired's Avatar
WHORE, Get off the site!
oldandtired is offline
Old 09-28-2010, 08:57 AM
  #10
JEFF69Z28
I LOVE ME SOME ASIAN'S ESCORT'S OR NOT,YUM-YUM.
