changing slick size
Pros
More surface area on the ground via larger radius, possibly more MPH, effectively raises gear ratio, changes weight bias.
Cons
Possible interference, effectively raises gear ratio, changes weight bias.
There could be more and some can go either way depending on your combination needs.
Curtis
Cons
Curtis
Not sure what kind of times,rpm and mph you run now but odds are you will see very little change.Just curious what are you trying to gain?If you are looking for larger changes look to the gearing. Approx 6 less rotaions of the tire in the 1/4 going to a 29" tire.... JMO
