40 amp mini alternator
Old 11-30-2010, 05:53 PM
ballsout1
JOURNEYMAN
Default 40 amp mini alternator
i got a mini alternator that i did up 1 wire and mounted low in my chevette. anyways its gonna be a limited street/ track car. i`ve got a electric fan, msd, fuel pump, and my lights/directionals. i`ve got a optima battery . car might see 30 miles a week on the street. whats the thoughts on running only a 40 amp alternator.....its small, light...cool.. maybe trouble.
ballsout1 is offline
Old 11-30-2010, 06:14 PM
chevyart
Default mini altenator
who makes it or what car is it from. also what bracket setup did you use to mount it and where did you mount it thanks art
chevyart is offline
Old 12-01-2010, 05:23 PM
ballsout1
JOURNEYMAN
i gotta laugh a bit..its off a fork truck. i think its gm based. i`ve got a fabbed up bracket on the power steering boss holes and i have a chrome , large, semi horshoe adjustable arm that was meant to be used on a top mount set up in 1 original alternator boss in the head....looks a little odd first glance but the traditional low mount you buy wont fit my chassis. anyways.. i`m a little concerned if i take it to some cruise nites with no charge in between... 40 amps i would think should run ignition, fan, pump, and lights.
Old 12-01-2010, 07:46 PM
not enough, you need an 85 amp 1 wire GM.
Old 12-14-2010, 05:45 PM
ImBack
I have a 35a Nippensdenso off a Toyota forklift on mine.
ImBack is offline
