Front motor plate
Old 01-23-2011, 10:30 AM
lanham
Default Front motor plate
When installing a front motor plate in a stock chassis does it matter if you weld your mounts from the frame on the inside of the frame or can you weld them on the outside of the frame?
lanham is offline
Old 01-23-2011, 12:12 PM
fast75vega
i really dont think it makes a difference..... ive done both before :wink:
fast75vega is offline
Old 01-24-2011, 04:33 AM
TheRabbit
TheRabbit's Avatar
Doesn't matter. Just make sure you make the mount big enough so it's not hard to get to the bolts. Some cars/ trucks have so much room it makes no difference, but some can be tight and a pain to get to and work around.
TheRabbit is offline
Old 01-24-2011, 08:22 AM
TheYellaBrick
TheYellaBrick's Avatar
Samesame; Take into consideration an engine pull at anytime in the future. EZ are the key letters here ! I build all my cars with that foremost in mind. I REALLY dislike fighting and engine and/or trans R&R.....
TheYellaBrick is offline
Old 01-24-2011, 11:46 AM
oldandtired
oldandtired's Avatar
Agree with DD.
I always leave a "step" cut in the front plate and mid plate. I drop the assembly on the frame and the plates hold it while I put the bolts in.
Very easy...
oldandtired is offline
Old 01-26-2011, 10:16 AM
spib
Originally Posted by oldandtired
Agree with DD.
Very easy...
x2
spib is offline
