SBC spun cam bearing
Old 01-23-2011, 10:48 AM
rusty40
Default SBC spun cam bearing
I have a sbc 350 engine that is currently set up to run mid 12's it lost a little oil pressure the last time it was ran so we pulled it apart and found out that it has spun a cam bearing. My question is can this be fixed? the block has had a lot of machine work done to it and everything looks good except for the cam bearing problem.
rusty40 is offline
Old 01-23-2011, 11:16 AM
hink
Default Re: SBC spun cam bearing
We have machined a lot of cam tunnels on OEM blocks because of misalignment issues spun cam barings ETC.
They offer over size cam bearings up to .040 over on the housing bore ID
Which cam bearings Clevite???????
hink is offline
Old 01-23-2011, 12:15 PM
fast75vega
yes it can. which cam bearing spun?
fast75vega is offline
Old 01-23-2011, 12:59 PM
rusty40
I would have to look to make sure but I think it is the # 3 bearing and yes we were using Clevite bearings.
What bearings would you recomend to go back with?
rusty40 is offline
Old 01-23-2011, 01:50 PM
hink
Clevite performance cam bearings 1349 you should stay away from.
We keep the ACL .010 over bearing P/N 5C004AS-STD on the shelf we like them over the Babbit bearings, You can also go with the Durabond performance cam bearings as well.
Good luck
hink is offline
Old 01-23-2011, 02:12 PM
fast75vega
Good luck
2nd that :wink:
Old 01-24-2011, 11:42 AM
  #7
oldandtired
oldandtired's Avatar
Since you have to pay for the set up and boring job, why not spring for the roller bearings?
oldandtired is offline
Old 01-24-2011, 12:04 PM
  #8
hink
Going the roller bearing with a 2.250 cam tunnel is really no gain as your using a STD. jouranl cam at that size and going to a 55MM roller cam bearing will most likely get you into the water jacket when reqrooving the oil grooves behind the cam bearings.
The more common size we do on the OEM blocks is go to the BBC cam tunnel which is .021 smaller then the 50MM cam journal and there is more power to be made with a babbit bearing over using roller cam bearings.
hink is offline
