how fast
Old 02-07-2011, 01:00 AM
billyd21970
Default how fast
1 have 406 with 13 to 1 light weight pistons roller 618 lift bowtie ported 205 alum heads.hvh brodix intake.turbo 400 with a break 5000 stall. 430 gears 31-14-15 in a 2950 car..just trying to get a ball park figure on how fast it should run??thanks for the feed back :roll:
billyd21970 is offline
Old 02-07-2011, 02:21 AM
fast75vega
im gonna guess 10.50's to 10.60's
fast75vega is offline
Old 02-07-2011, 11:49 AM
kwkracing
mid 11's
kwkracing is offline
Old 02-07-2011, 12:39 PM
fla1976
fla1976's Avatar
I'd estimate a 10.65 area.
fla1976 is offline
Old 02-07-2011, 02:39 PM
TS1955
Originally Posted by kwkracing
mid 11's
X2
TS1955
TS1955 is offline
Old 02-07-2011, 02:45 PM
shawnp
Where will you be running at? World of difference running at sea level or racing in the clouds at Denver. I would say you are a 10.80 player give or take a .15 depending on your elevation.
shawnp is offline
Old 02-07-2011, 03:58 PM
  #7
spib
x2 10.70-10.90
spib is offline
Old 02-08-2011, 02:15 AM
  #8
JEFF69Z28
Default Re: how fast
THOSE BIG TIRES R KILLING YOU WITH THAT GEAR.
JEFF69Z28 is offline
Old 02-08-2011, 02:40 AM
  #9
billyd21970
what size tire do you think would work best or what gear should i go to?if i can get 10.30cto 10.50 out of it ill be happy for the money i have into it.?thanks for everyones come back.i have been out of racing for 12yrs and just trying to get everything built back up.
Old 02-09-2011, 02:20 AM
  #10
JEFF69Z28
I HAVE A BIT BIGGER CAM AND 210 HEADS IN MY MONTE CARLO IT WEIGHS 3150 WITH ME IN IT. I RUN 28X9X15 INCH SLICKS AND A 4.56 GEAR,8 INCH CONVERTER AND RUN 10.20'S ON MOTOR.I HAD A NEW CAM GROUND FOR MY MOTOR AND IM HOPEING FOR 10.00'S OR A HIGH 9,WE SHALL SEE WHEN THE TRACK OPENS UP THIS MARCH.
