fiberglass doors?
Old 03-17-2011, 11:37 AM
fast75vega
Default fiberglass doors?
my fiberglass doors are flexed out up top at the window frame part of the door. how can i fix this problem? do i have to cut relief cuts and reglass or can i heat them and bend them back..... ? thank you
fast75vega is offline
Old 03-17-2011, 08:15 PM
TheYellaBrick
TheYellaBrick's Avatar
Can you post a couple of pics ? Both with the door closed and open.
I think the method of correcting this is going to depend on where the deformation point is. Is it in a single point or along the full length of the window frame(curved) ?
TheYellaBrick is offline
Old 03-18-2011, 09:11 AM
fast75vega
it starts just a few inches up the frame itself and the top of the frame is about 1/2" to 1" away from the jam.
Old 04-24-2011, 06:00 PM
coolracing
I just installed a set of glass doors last night and one door had the same problem i used a set of light weights and a heat lamp and the window frame moved rite where it had to go. mine needed to move about 3/8 of a inch worked perfect. Hope it helps
coolracing is offline
