Shaft rockers needed for Brodix 11x
APPRENTICE
I have a set of brodix 11x heads 23 degree for sbc. Can anyone tell me what exactly I need as far as shaft rockers are concerned , offset, etc. I do need to have 1.6 ratio rockers. Thanks alot Rob.
I have Brodix 23* 10's RP,Sp,FP's i think they are the same. I have .250 int offset T&D's and .180 offset lifters (required). I'm not absolutely certain, but a call to Brodix would confirm if they use the same rockers. i can look up the T&D rocker #'s for you if you need.
