Crank/Cam
1. How much crank thrust is allowable on a stock crank shaft? 327/LE 275HP stock motor.
2. W/ Stock internals, 202/160 aluminum heads, new RPM intake, 4-spd trans, what is a good cam lift/duration without going to high but getting decent choppy sound?
3. Oil pump: stock or high volume???
4. Quiet gear drive... still pretty noisy? Bad idea/good idea? never ran one....
Just freshening this motor; keeping it pretty stock.
4 Speed thrust clearance .005" to .009"
Hydraulic Flat tappet, Comp Cams 12-242-2 or 12-246-3, after more of a lopey sound, 12-600-4 or 12-601-4 Muther Tumper cam.
Stock Volume pump is fine for Street use.
Gear drives I would stay away from, I would stay with a good roller timing chain.
