convereting sbc to roller lifters
Old 07-30-2011, 08:55 AM
blownsbc41
Default convereting sbc to roller lifters
can someone tell me the difference between a standard and offset lifter used on sbc, i am intrested in converting over to a roller set up on my blown 350, i understand the use of connected lifters saves me the problem of welding the bosses into the block, but not clear on offset lifters, any help would be helpfull. thanks[/b]
blownsbc41 is offline
Old 07-30-2011, 10:50 AM
TS1955
All of your 23 degree headed sbc engines typically uses a standard lifter. Most all of the 18, 15, & 13 degree etc. headed sbc engine uses an off set lifter. Which means that the push rod pocket is not in the center of the lifter and usually on the intake lifter. This helps in keep the push rod as straight as possilbe to the rocker arm. And when you get into the 18 & less degree heads they require an off set rocker also. This is all done also to get the push rod away from the intake ports so they can be made bigger.
TS1955
TS1955 is offline
Old 07-30-2011, 08:25 PM
Like TS1955 said, but there are a number of 23* heads that do take an offset lifter and also a an offset rocker. EX: i have a set of Brodix 10's 23* that takes a .180 offset lifter and .250 offsst rocker. As TS1955, it's because the ports are so big the pushrod won't clear the intake port. There's probably more, but i only have the Brodix 10's as as example. As i understand it most of the higher flowing 23* heads do have to use the offset lifters and the offset rockers. the Brodix 10's that i have flow close to 320 CFM at .700 lift int.
Old 07-31-2011, 05:41 AM
TS1955
Thanks for the info Zip. I didn't know some 23 degree motors used off set lifters.
Sorry to misinform you blownsbc41
TS1955
TS1955 is offline
Old 07-31-2011, 08:14 AM
JimmySmith
Zip is dead on with a zero, even tho he may be sitting on his porch watching the traffic go by LOL Later J.Smith 4621 racing
JimmySmith is offline
