lean condition
Old 07-31-2011, 02:16 PM
melson3086
JOURNEYMAN
Default lean condition
Say if you were running a blown alcohol sbc what kind of EGT's and characteristics would you find this may sound stupid but I know you can run a motor lean so lean that it won't really make any power or hurt its self! Just having a little problem getting my car to really make any power
melson3086 is offline
Old 08-01-2011, 10:08 AM
blowninjected540
I like running my EGT around 1150 deg is your motor injected or carb.
blowninjected540 is offline
Old 08-01-2011, 04:02 PM
melson3086
JOURNEYMAN
Carb but the EGT's are only going up to 800 ish but the motor is wantn to run a little warm
Old 08-05-2011, 06:36 AM
blowninjected540
800 on the egts is alot lean thats why its running warm
Old 08-21-2011, 11:29 AM
kwkracing
More details, you should be making some hp!
kwkracing is offline
Old 08-21-2011, 12:17 PM
hammertime
the higher the # the leaner it is
hammertime is offline
Old 08-21-2011, 12:41 PM
  #7
wazup
Dont have an EGT set up on my car but what would be a good reading on a single EGT in each header?
wazup is offline
Old 08-21-2011, 03:49 PM
  #8
melson3086
JOURNEYMAN
Well I have fattened it up a bunch and now have the biggest jets I own in my carbs and the motor is still running 185 degrees still seams to be a little to hot with alcohol to me. Motor was wantn to run over 200 be for. I have jumped the jets up a lot. But I think my EGT gauge isn't worth a crap it still reads the same and I've picked up over 1/2 second. I would think the actual EGT would have changed.
Old 08-22-2011, 11:26 AM
  #9
hammertime
1075ish
Old 08-22-2011, 12:14 PM
  #10
shawnp
Is the motor idling high? Are you sure you did not suck an intake gasket?
shawnp is offline
