ALCOHOL DOMINATOR , WHAT IS A GOOD JET STARTING POINT???
JUNIOR BUILDER
HI EVERYBODY , I HAVE A 555 BBC NESSBIT MOTOR , 15-1 COMPRESSION, I EM GOING TO USE AN 1150 ALCOHOL DOMINATOR, THE MOTOR MAKES ABOUT 820 HP AT THE CRANK IN MY ALTTITUDE ..WHAT IS A GOOD START POINT FOR THE JETS, WHAT SIZE OF JETS SHOULD I START WITH TO BE SAFE . I DONT WANT TO MILK THE OIL AND ALSO DONT WANNA LEAN IT OUT , ANY IDEAS WILL BE APPRECIATED, THANK YOU
What brand carb? I ask because I know each builder is a little different. For instance with my Rupert carb that is very fat on the idle circuit I have 161's in my carb. With the APD carb that is lean on the idle circuit I would look at 196-200 on the jets. This would be a 1250 on a 582.
