MSD 2 Step and Methanol?
Old 08-28-2011, 06:39 AM
maxpower671
SENIOR BUILDER
Default MSD 2 Step and Methanol?
is staging/launching a 2 step MSD and methanol a no-no?
car is 2800#, powerglide, 5500 stall
does not 60' consistently on the chip? :?:
maxpower671 is offline
Old 08-28-2011, 07:10 AM
markdunlap
Default MSD
I did run into a situation like that.
SBC 377 with a RONS toilet. It did not come up to RPM on the 2 step cleanly and left line erratically. Replaced it with a starting line air cylinder for RPM control and problem went away. May have been the tune up on the Toilet?
markdunlap is offline
Old 08-28-2011, 10:10 AM
hammertime
Default Re: MSD 2 Step and Methanol?
A 2 step is the only way to fly, methanol or gas when bracket racing.
I'd look at chassis/converter/fuel system.
hammertime is offline
Old 08-28-2011, 05:00 PM
bbchevy
Sounds to me like you NEED a RONS converter HELPER!
Its a Electric Leanout w/a Pill tat you can adjust,and Its applied when the Transbrake is on.Lots of times,the B/Valve is FAT and the Car w/NOT come up on the Verter!!!
Later
G 8)
bbchevy is offline
Old 08-29-2011, 03:18 AM
curtisreed
curtisreed's Avatar
Is he running injection or carb?
curtisreed is offline
Old 08-29-2011, 07:21 AM
bbchevy
Default ?
Thought is was a Rons TOILET,........?Maybe i'm thinking of a DIFF.set~up?
Later
G 8)
bbchevy is offline
Old 08-29-2011, 08:13 AM
  #7
maxpower671
SENIOR BUILDER
i'm running Enderle mechanical injection. thinking i'm rich on barrel valve and main pill.
ignition is old Mallory distributor and coil, maybe time for upgrade as well... car's 60', ET and MPH all over the place with no changes... :?:
Old 08-29-2011, 08:16 AM
  #8
maxpower671
SENIOR BUILDER
thanks David!
Old 08-29-2011, 10:19 AM
  #9
curtisreed
curtisreed's Avatar
Sitting on the 2step with the barrel valve wide open can cause the engine to go rich depending on how long you have to wait for the light. A starting line enhancer would help.
As you said you may already be rich to start with and that would make things worse.
David is not wrong though about looking at your chassis set-up. Have you videoed your car?
Curtis
Old 08-29-2011, 10:24 AM
  #10
shawnp
We ran enderle injection for a few years. I strongly suggest you get a Starting Line Enhancer on the car if you don't have one. It helped us out and keeps your 2 step time minimal.
shawnp is offline
