Waterpump flow
Old 09-10-2011, 05:20 AM
oldandtired
oldandtired's Avatar
Default Waterpump flow
I have been searching online for waterpump flow and can't seem to find anything. I'm looking for a chart that shows flow by RPM using stock pully diameters, application is BBC.
Does anyone know where I can find this?
Thanks,
oldandtired is offline
Old 09-10-2011, 06:03 AM
markdunlap
Default Water pump flow
That is engineering data that you don't see commonly. I would contact a manufacturer tech line directly. They will have it.
The only numbers I see are for electric pumps which is 35 GPM.
Maybe we have a pump tech guy on here?
markdunlap is offline
Old 09-10-2011, 06:38 AM
TheYellaBrick
TheYellaBrick's Avatar
You're right, not a commonly asked question. Would be great to see a flow chart on the different engines and pumps designed for those engines.
TheYellaBrick is offline
Old 09-12-2011, 10:41 AM
oldandtired
Thanks, I'll check with a couple of the aftermaket manufacturers and see what they say. I will post the results.
Old 09-12-2011, 02:43 PM
TheRabbit
TheRabbit's Avatar
Just curious why do you need to know that?
TheRabbit is offline
Old 09-16-2011, 04:42 AM
oldandtired
I am building a street car for a customer with twin turbos. Depending on boost, it's going to make a lot of heat at idle and I may suppliment the cooling system with an electric pump for idle to 2000 rpm, then let an underdrived conventional pump take over. There is such thing as too much flow thru the radiaton and was trying to get the facts down.
Old 09-17-2011, 08:34 AM
  #7
mtheulen
JOURNEYMAN
Call Don Meziere out in Ca. They have done extensive research in racing(drag-nascar) and street stuff.Don know's his stuff
Mike
mtheulen is offline
Old 09-17-2011, 03:09 PM
  #8
oldandtired
Thanks, I'll follow up next week.
