need more hp
Old 09-22-2011, 06:52 PM
firemanjeff
APPRENTICE
Default need more hp
I have a 30 over standard crank flat tappet cam with a 555 lift flat top pistons with out changing to much how can i make more hp i circle track race and can stay within a car or 2 but dont have enough to pass any suggestions
firemanjeff is offline
Old 09-22-2011, 07:37 PM
TheYellaBrick
TheYellaBrick's Avatar
What are the engine restrictions for the class you run ?
TheYellaBrick is offline
Old 09-22-2011, 08:02 PM
firemanjeff
APPRENTICE
none
Old 09-23-2011, 05:52 AM
cncmotorsports
Camshaft profile in circle track engines is very crucial to having good acceleration power throughout the entire RPM band. Compression, Camshaft, Cylinder head, intake manifold, and carburetor are all a balance set in order to make your combination work to its very best.
Tell us a little bit more about your current set up, Compression ratio, Heads, Intake, and Carburetor being used. And car weight
cncmotorsports is offline
Old 09-23-2011, 08:19 AM
firemanjeff
APPRENTICE
not sure how much compression Cam is a speedway tight lash flat tappet [email protected] int 252 exh 260 lobe separation is 106 gross valve lift int .542 exh .555 spring pressure is 120. Heads are Aluminum Pro comp 190cc runners 64cc chambers set up for my cam. Victor Jr intake no porting or polishing. Carb is a Holley 390 4brl 30 over flat top pistons car weights 2800 wet with driver.
Old 09-23-2011, 09:03 AM
cncmotorsports
Changes I would make, add dome pistons, change to a roller cam, and upgrade to a set of AFR 195 or possible 210 CNC ported cylinder heads.
The Pro Comp heads, flat tappet camshaft, and flat top pistons are holding you back with the no restriction rules.
Old 09-23-2011, 09:19 AM
  #7
curtisreed
curtisreed's Avatar
I think you missed the hardest part of answering his question. :lol: :lol:
Curtis
curtisreed is offline
Old 09-23-2011, 10:32 AM
  #8
firemanjeff
APPRENTICE
well the headas will have to stay what size dome pistons would you suggest with the cam i have and then what came also would you suggest
Old 09-23-2011, 01:22 PM
  #9
cncmotorsports
The biggest dome, but this will require tearing down the engine.
Curtis, Thank you for pointing out "with out changing to much" I missed that part.
Old 09-23-2011, 04:31 PM
  #10
firemanjeff
APPRENTICE
could u give me a little more detail and other options also would greatly appreciate it
