switch panel
Old 12-11-2011, 04:36 PM
briscoman
Default switch panel
chris alstons in dash panel, panel is hot but switches will not work. Is there a ground needed to the panel, panel is alum. Prob. simple just missing something, thanks for the help.
briscoman is offline
Old 12-11-2011, 05:59 PM
TheYellaBrick
TheYellaBrick's Avatar
Are you talking about toggle type switches?
Standard switches don't use grounding, just power users like lights, pumps, fans and such. Switches with internal lighting DO require a ground, however.
What exactly is not working when the individual switches are turned on ?
TheYellaBrick is offline
Old 12-11-2011, 08:35 PM
briscoman
standard off/on switch. botton attaches to hot bar and top to function. Bar is hot but pump and fans don't come on. All are fused.
Old 12-12-2011, 08:43 AM
TheYellaBrick
You have juice at the pump and fans ? Are they grounded directly to the battery ? I use a grounding bar to attach all my peripherals to and run a large gauge wire to the battery.
Proper Grounding is the cause of a large percentage of electrical probs.
