messuring egt
Old 12-18-2011, 05:55 PM
hotrod1994
Default messuring egt
if the exhaust gas is 1200 degrees would the header also be 1200 degrees and would i be able to check the the temp with an inferred thermometer?
thanks logan
hotrod1994 is offline
Old 12-18-2011, 07:27 PM
If you are able to ride on the fender and point the inferred gun at 100 mph you can, it's not going to go to 1200 degrees except at wide open throttle, it should idle around 500/700 degrees.
Old 12-19-2011, 12:54 PM
hotrod1994
ok thanks zip
Old 01-03-2012, 10:01 PM
ewing
The temp on the outside of the tube will be lower btw.
Even with egts inserted in the tubes, the readings often tell more about the tips protrusion into the exhaust flow,
than the actual exhaust temp.
ewing is offline
