transmission problem
Old 03-04-2012, 03:00 PM
srt5091
Default transmission problem
I have a powerglide which I recently rebuilt. We put in a new 588 bbc, and new converter. When motor comes up close to stall, the car breaks loose. won't do it at lower rpm. Any help as to where I should look, please let me know.
srt5091 is offline
Old 03-04-2012, 03:52 PM
TheYellaBrick
TheYellaBrick's Avatar
Just to confirm terminology;
What exactly do you mean by 'the car breaks loose' ?
TheYellaBrick is offline
Old 03-04-2012, 05:14 PM
srt5091
when the transbrake is set and i am trying to stall test the converter the car moves forward at 6000 rpm it will not do it at 5000. i dont know where to look to try and diagnose the problem.
srt5091 is offline
Old 03-04-2012, 07:48 PM
rob41willys
SENIOR BUILDER
How many reverse clutches? sounds like reverse clutches not holding.
rob41willys is offline
Old 03-05-2012, 03:41 AM
srt5091
Default Transmission problems
What I mean is the car trys to move with the brake set, It has 5 clutches in reverse. Thanx
srt5091 is offline
Old 03-05-2012, 05:22 PM
Might correct the problem by re-adjusting the band, instead of backing off 3 1/2 turn try 3 turns.
Just a thought :?:
Old 03-09-2012, 05:58 PM
  #7
TS1955
Sounds like you might have a worn pump and not producing enough pressure.
TS1955
TS1955 is offline
Old 03-14-2012, 12:36 PM
  #8
johnracer
Did you check what we talked about the other day? If you need any help, you know I'm less than a mile and a phone call away...
Johnny
johnracer is offline
Old 03-15-2012, 03:47 PM
  #9
srt5091
Default transmission problems
ok guys, found the problem, it was in the valve body, I fixed it. Thanks for everyones input.
srt5091 is offline
