Engine loses power after launch
Old 10-01-2012, 03:57 AM
lodilobo
Default Engine loses power after launch
I'm running a Vega with a 750 h.p. small block with a 1090 Demon carb (96 jets). I use a trans brake, and come out at about 4500 rpm. When the car hooks well, and the front wheels come up, the motor will lose power instantaneously, then regain it....sometimes twice. I have a vent tube from breather to breather on the carb, and the float levels are where they should be. The car is going 9.50's @ 143, but I'm sure I could be in the very low 9's, if this problem goes away. There is really no loss of power or misfiring after the initial launch. Any suggestions?
lodilobo is offline
Old 10-01-2012, 04:44 AM
fast75vega
sounds like you need jet extensions in the rear of the carb :wink:
fast75vega is offline
Old 10-01-2012, 06:06 AM
itsabird
x2
itsabird is offline
Old 10-01-2012, 09:03 AM
lodilobo
Already has them.....thanks anyway.
lodilobo is offline
Old 10-01-2012, 09:23 AM
fla1976
fla1976's Avatar
Possibly a partially clogged fuel filter or weak fuel pump. What size fuel lines?
fla1976 is offline
Old 10-01-2012, 10:39 AM
lodilobo
Fuel lines are 10 AN......pump and filter are new...MagnaFuel pump w/ Aeromotive filter. I'm in the process of checking the fuel flow at the carb. That should tell me something. Also.....the regulator is new (Aeromotive). Fuel pressure gauge stays at 7.5 lbs.
lodilobo is offline
Old 10-01-2012, 04:01 PM
  #7
TheYellaBrick
TheYellaBrick's Avatar
Might want to check your fuel pickup in the tank....
TheYellaBrick is offline
Old 10-01-2012, 04:59 PM
  #8
mopar1968
mopar1968's Avatar
Fuel isn't coming out of the air vent and going down into the engine is it :?:
mopar1968 is offline
Old 10-01-2012, 05:09 PM
  #9
wrightway
SENIOR BUILDER
Are you running a power valve in the rear?
wrightway is offline
Old 10-02-2012, 03:59 AM
  #10
fast75vega
that was gonna be my next question too ...... :wink:
