Crank to crank engine connector ???
Old 12-22-2012, 01:57 PM
wingdwarrior1
Default Crank to crank engine connector ???
Have seen several tractor pullers with two & three engines connected crank to crank...what is that connector called ????
Thanks !!!
wingdwarrior1 is offline
Old 12-22-2012, 02:35 PM
TheYellaBrick
TheYellaBrick's Avatar
This is a joke, right ? You have 'several' but don't know anything ABOUT them ? So YOU didn't build them ?
:shock: :shock: :shock: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
TheYellaBrick is offline
Old 12-22-2012, 03:42 PM
wingdwarrior1
Can ya read ???? have SEEN several...
Old 12-22-2012, 05:32 PM
ajk
ops: ops: ops: ops:
ajk is offline
Old 12-22-2012, 10:38 PM
TheYellaBrick
Sorry dude, I never saw the seen but see the seen now ! My bad ! Old eyes and all...I'm splittin' THIS scene... ops: ops: ops: ops: ops:
'Coupler' is the word you're looking for I believe
Old 12-23-2012, 07:13 AM
wingdwarrior1
Thanks...
Do they make them for V-6 engines ??
Plan to put 2 ,6s together for12 cyl. veh.
Old 12-23-2012, 07:22 AM
  #7
csx8506
SENIOR BUILDER
Default crank to crank engine connector??
Wing,
The crank doesn't know if it's in a v-8, v-6, or whatever. If you can't get one from a store, any good machine shop can make you one.
Happy pulling
csx8506 is offline
Old 12-23-2012, 07:33 AM
  #8
TheRabbit
TheRabbit's Avatar
Some multi-engined tractors run the motors hooked crank to crank. They have a coupler bolted in place of the flywheel that is splined and a coupler that fits in place of the damper pulley that is splined, and they slide together. Kinda hard on the crank that has to take the power of both motors! On the newer built tractors, all the engines are mounted separately and have their own clutch and are bolted to a crossbox, that transmits all the different engines power to the single planetary rearend.
Here's a link for you. Scroll down a little for some pics.
http://www.tedderpullingperformance.com/
TheRabbit is offline
Old 12-23-2012, 12:51 PM
  #9
itsabird
Pretty cool link, there rabb 8)
itsabird is offline
Old 12-25-2012, 07:09 AM
  #10
TheRabbit
TheRabbit's Avatar
I have the offroad, 4x4, mud racing, hill climbing, truck and tractor pulling, etc. stuff covered.
I have lots of other absolutely worthless information too if you need it! lol
BTW some of the engineering the tractor pulling guys do is amazing. Horsepower levels are insane too.
