Rocker to spring clearance
Old 11-07-2013, 03:07 AM
ssym
JUNIOR BUILDER
Default Rocker to spring clearance
Building a SBC. Isky EZ roll solid lifters, Comp Gold 1.6 rockers and 1.550 springs.
7.950 pushrods give good geometry, but I end up with only .025 clearance between the retainer and the rocker arm.
Is this enough or do I need to look at lash caps or other solution for more clearance?
Steve
ssym is offline
Old 11-07-2013, 04:17 AM
wmeabates
Steve, If You have .050 or more of shims under the springs You can get .050 less height locks to lower the retainer and readj.the spring. Bill.
wmeabates is offline
Old 11-07-2013, 07:31 AM
curtisreed
curtisreed's Avatar
I prefer to see .060" minimum.
curtisreed is offline
Old 11-08-2013, 06:34 AM
ssym
JUNIOR BUILDER
Thanks guys. I'm in a quandary. Probably going to look at other rocker arms. I have .045 locators with a 1.900 install height. I hate to trash these rockers or put floating aluminum in the pan.
Steve
ssym is offline
Old 11-08-2013, 11:09 AM
curtisreed
curtisreed's Avatar
Have you considered cutting the rockers for clearance?
Old 11-09-2013, 04:31 AM
ssym
JUNIOR BUILDER
I'm getting a lot of input on this. Most recommend a minimum of .040 to .050 clearance between the rocker and the retainer/spring.
I'm curious as to what happens with less? Am I sure to make contact with the rocker with only .025? It is a blower motor and won't see more than 7000 RPM.
Steve
ssym is offline
Old 11-09-2013, 04:51 AM
  #7
markdunlap
Default Rocker
Better not take the chance. Heat expansion can change clearances.
There is nothing wrong with adding clearance by carefully removing material from the rocker arm. Just don't let any particles get into the trunnion or roller tip area. Tape them off if you have to. Rinse them afterward and soak them in oil to pre lube them.
You should be able to do a full set in less than an hour.
markdunlap is offline
Old 11-09-2013, 06:49 AM
  #8
hammertime
x2
hammertime is offline
Old 11-09-2013, 07:34 PM
  #9
curtisreed
curtisreed's Avatar
Steve
You have to think about spring surge and rock. Do some research on YouTube for spintron videos. If you see how much springs move around you would be amazed.
Curtis
Old 11-10-2013, 02:08 PM
  #10
TheYellaBrick
TheYellaBrick's Avatar
WOW ! :shock: :shock: :shock: :shock: :shock: :shock: :shock:
http://www.youtube.com/watch?v=a-fs8CFnZ_g
WHAT action makes the valve spring rotate like this ?!!!
http://www.youtube.com/watch?v=6Vz4mjPKXJ0
TheYellaBrick is offline
